The configuration changed from time to time, but the dimensions from the carb to the trans would be the same. The '66-style linkage had the linkage adjustment in a screw-on slotted shaft at the carb end. In about '70, it became a sliding joint held with a bolt. By '80, the adjustment "joint" was moved to under the cowl (obviously to thwart changing the adjustment from factory adjustment . . . although I found an easy way around it). This was on the C-body and later R-car linkages.
When installing an Edelbrock 4bbl intake manifold, they have an extension for the threaded rod on the '66s, although I had to file and shorten the basic rod to get things to work as I wanted them to. No big deal.
On the '65+ models with the threaded rod adjustment, the base adjustment was to put the carb at hot base idle position. Pull the linkage forward and adjust the slot to where it just touches the carb linkage stud, then put 2 turns of pre-load (lengthen) onto that first adjustment. As the base and part-throttle upshifts are a little early, I added 2 MORE turns of pre-load to our '66 Newport and it worked great. NO trans durability issues, either.
Basically, adjust the linkage to get a just off-idle upshift into 3rd so the engine is right at 1000rpm after the shift. With a 3.23 axle, that's about 25mph. With a 2.76 axle, its about 28mph. This makes high gear acceleration "on the engine" rather than "on the converter" if it upshifts into 3rd too soon . . .which just works better for the car.
These linkages would be pure salvage yard parts. Just get the whole thing, including brackets, bellcranks, rods, etc.! C-body B/RB items preferably, but B-body items might fit too. As these items would not be really "in demand" items, the prices should be very reasonable, I suspect.
