When the 400s were still being produced, if one might have been installed in a 3/4 ton (or heavier) pickup truck, with over 8600lb GVW, there's a good possibility that it would not have had an EGR valve on it due to the HD emissions. Of course, the calibration of the carburetor would be different, too. And ELB engines, the first ones, had no EGR valves on them, IIRC.
In reality, a 400 is just an over-bored 383 (with a different block casting to support the larger bore size), with a lowered compression ratio.
Of course, for "testing purposes", you can plug the vac line going to the EGR valve and see what happens.
Why curious about this?
Take care,
