thethee
Last couple of days I've been working on trying to get my cruise control working again and found that in fact the cruise part of my brake light switch had gone bad. When looking online th non cruise switches are readily available, but the cruise ones are hard to find. The one NOS I found was 125$ and that's just too much for me. So I figured I'd give it a go and try and fix my switch, even though its another one of those non servicable parts, and provide some pictures of the internals for the rest of you and show how it works.
This is from my '75 Imperial but I think the switch is used across many years and models. Don't mind the cut wire, that was me and I'll patch it later.
The blue wire connectors are mounted on the cap of the white plastic housing. The cap is glued on but with a sharp slim knife I was able to break the connection cleanly by being careful and going all the way around and not just force it at one end.
Components:
Center white stalk operates both switches simultaneously. Normal condition is pushed in with open circuit in break lights part and closed circuit with cruise control part. When pressing brake pedal switch is extended closing brake circuit and opening cruise circuit.
Cruise:
Brake:
The first problem with cruise part of the switch was center stalk, you can see some spots on the narrow right side. Plastic deteriorated so that it was out of round causing cruise circuit to be open all the time. Sanding it down with some fine grit sanding paper was enough. Second issue was that somehow, on the cap, the copper rivet lost it's connection to the brass wire connector. Some soldering fixed that.
Hope this helps anyone with a broken cruise control switch.
Components:
Cruise:
Brake:
