I've never seen any adjustment in the service manual for any adjustment to the speedometer itself. If you know of a adjustment procedure to the speedometer let us know. The only adjustment I've seen is the speedometer pinion gear chart for the transmission. That would be hit or miss because the chart doesn't have modern metric tire sizes. I guess you could play with adding or subtracting the pinion gear ratio. The gear ranges from 24, 25, 26, all the way to 37 teeth per gear. You could keep swapping them out until you get it close. You could use a GPS to check your actual speed to speedometer accuracy.
