Got the carpet with mass backing, makes it quite heavy and not very pliable. I am thinking that next time not the heavy stuff. And, and, and, I want to try next time to get separate padding. I tried to remove the padding anywhere I had to drill, cut or need to be thin....but I missed some. When you try to cut thru the padding you will find it a nitemare, no matter what. By putting padding down first, this problem would go away, just use the spray adhesive, no sweat. Also, even though the heavy stuff is pre-formed, there are a few areas to mold.....which you can try with some heat on the rubber side.....but difficult to change. Overall, I am good with what I achieved, but it aint perfect. I have some lumps and raised areas that cannot go down but will not be a problem for my roadkill project. The wife said wow, so far now as the sill plates go back on, and the console will also hide some of the fitment. I would just go about it a bit differently next time.
