I've acquired a Felpro gasket set for the water pump and timing cover (this is a 318). I have the early timing cover so the water pump is the cast iron type.
No instructions came with with it. A small tube of Felpro grey RTV came with it, but I presume this is for the small cork pieces at the front of the oil pan.
On Felpro's website, you can punch in the product number and you'll get info on that product, but in this case there is (again) no available instructions. I was looking around the site for general info about dressing paper gaskets but can't find anything.
Permatex makes a water pump and thermostat RTV sealant, claimed to be their best for glycol resistance or compatibility. It comes in a small tube, nobody in my town carries it, I have a tube that might be 5 years old, still some left. If I can't make that work I have some ultra black.
But my basic question is - do you dress a paper gasket? A paper water pump gasket? The timing cover gasket is mostly just in contact with the block, but there is a portion of it that is in contact with the coolant passage, so attention must also be paid there.
