Today at 4:48 AM #1 N Npt 383 New Member Joined Jan 2, 2024 Messages 5 Reaction score 0 Location Bristol Hi everyone . Just re fitted trans after rebuild and now all the shift points are wrong. Just reconnected the linkage as it was when I removed the gearbox. Is it because there isn't enough fluid?
45 minutes ago #2 Big_John Illegitimi non carborundum FCBO Gold Member Joined May 21, 2013 Messages 21,251 Reaction score 31,908 Location Marcellus, NY Check fluid with engine running, trans in neutral?? What about the throttle linkage (some wrongly call it kickdown). Has that been adjusted per the FSM? What engine and trans?
