I'm working on a 440 motor (installing timing chain) and I don't have a torque wrench (for damper bolt and timing chain cover bolts etc) . (Actually I'm wondering how important a torque wrench is as opposed to tightening by feel). Anyway if I did buy ONE what is the best size torque wrench to buy? I'm talking about drive size (3/8", 1/2" etc) and torque range ( that is range of ft lbs the wrench should cover)? Best brand is nice but optional. Thanks Paul
I wouldn't use one for what you are doing.
Next... I used to be partners in a A2LA accredited calibration lab. We quite literally calibrated thousands of torque wrenches and I personally have done hundreds of them. Here's what I can tell you about torque wrenches... We also did a ton of other stuff, but I digress...
First, the big names "Snap-On" etc. aren't much, if any better than the cheap Harbor Fright ones. In fact, there was a run on some real crap from Snap-On for a while (Had the guys at the nuc plant going crazy) and they were off right out of the box.
The most accurate for home use is a bending bar type. I personally like these. 2% accuracy . There are dial types that are as, or more accurate, but the bending bar type is much more robust.
The ones most used are the clicker types. 4% clockwise and 6% counterclockwise accuracy over the upper 80% of the range was typical. A lot handier to use, but not as accurate and you have to remember to set them to a low value for storage.
So... The one to buy is actually two if you want to torque everything... One would be a 1/2 drive with maybe a 20-150 lb/ft range and another would be a 1/4 drive 20-200 lb/in. Note lb/in versus lb/ft.
But again, for what you are doing, I wouldn't use a torque wrench. The pros never do... I'm not a pro, but for an engine, I use a torque wrench on head bolts, main cap bolts and rod nuts.
