Wilkiethegrid
I am having to part with my 1963 Dodge Custom 880 which I rescued from a Derby candidate in 1996. Mostly original California 35,645 miles. 361cid 727 Torqueflight. Many factory options. It has been garaged since I have had it. Interior is original showing prior signs of sun damage. It’s under a cover now on my driveway. I lost garage space. The car (Sandy) needs a new home. Located in the San Francisco Bay Area.
PM me for more info.
Work completed :
*11-13-2001 33,426mi Complete repaint, Stainless Steel trim polished and Front bumper re-chromed.
*12-12-2018 33,438 Fuel pump, tires, Battery, oil & transmission service.
*3-25-2019 33,500 New brake master cylinder, rebuilt brake booster, new hoses.
*6-21-21 Paint Correction
*8-18-21 33,959 Replace fan belts and fan clutch. Repair power steering pump. Wheel bearings re-packed
*5-18-22 34,025 Petronix installed
*3-29-23 35,000mi Rebuilt cylinder heads(valve stem seals were deteriated), replaced freeze plugs.
*3-22-23 Rebuilt Carter #3685s 2bbl carburetor.
*3-24-23 Radiator boiled out and repaired, re-painted.
*6-30-23 Rebuilt Front steering and suspension.
*11-9-23 35,250 Front end alignment.
*2-9-24 35,388 Converted drive shaft from Trunnion joint to conventional Spicer joint.
Work completed :
