1967 NYer front suspension/drum brakes/torsion bars
greasemonkeyman
Port Saint Lucie,Florida
I have parts from a 1967 NYer front suspension.Upper and lower control arms,factory sway bar and end links,factory 47" torsion bars.I also have a clean front radiator support for a 26" radiator and good used 26" radiator.Also Misc interior parts like brake pedal assembly,window motors,power bench seat motor,etc.
I'm looking to convert my 65 Fury from manual drum to power drum brakes. I assume your 67 New Yorker came with Power brakes, correct? Are they disc or drum? Do you have the complete setup from brake pedal to power brake booster, including the pedal assembly rod?
Thanks
Thanks
The only thing I have left from the brake setup is the complete large front brake drum with backing plate and all internal assemblies with the shoes and springs still attached to the wheel cylinders. I may also still have the 4 wheel drum proportioning valve.
