For Sale 1969 Chrysler Newport- - $7500
67newport
eastern oh
Feedback: 1 / 0 / 2
This car was my grandfather's and was garage kept until a year ago when I had it towed from Virginia to Maryland. The odometer reads 10,000 but the numbers do not click over so this is most likely not the accurate number of miles. My grandfather purchased this car from the original owner approximately 25 years ago. In the 25 years my grandfather had the car he kept it in a garage and drove it around the neighborhood. I recently replaced the radiator and brake booster, the muffler, and the ballast resistor (for the ignition). I had it professionally cleaned. The soft top of the convertible was replaced in 1995. The car was re-upholstered in the 90's also.
The car has a few small issues- the gas gauge does not work (but is an easy fix); the passenger seat belt needs to be replaced, there is a tear in the upholstery on the driver and passenger side doors. The brake booster was replaced, but there may need to be some additional brake work. (You can definitely test drive the car- the brakes are just a little less sensitive). The odometer does not indicate a change in numbers, so it states 10,000. I'm not sure of the actual amount of miles the car has on it. I've had my car shop look everything over, and they have road-tested the car. I have also driven it recently.
I do not have the build sheet.
The car is listed as $7500 or best offer.
I am currently keeping the car at RPM in Laurel MD. If you would like to see the car please email me and I will make arrangements to be there. Thank you!
