For Sale 1971 Monaco Wagon
LocuMob
Fluid Technician with a hat
Legendary Member
Winnebago Mn
Feedback: 7 / 0 / 0
I'm putting my 1971 Monaco wagon out there for anyone interested. I have other cars ahead of this one slated for major work, so this will sit and wait. It is in covered storage, so it's out of the elements.
383-2/727 Engine is in need of rebuild. Does run and move under its own power. It got hot and blew steam out the radiator, and now has a knock. The engine needed a rebuild when I got it, I just hoped it wasn't the case. It had an oil pressure issue when I got it, and a high volume pump didn't make a difference. It was truly on borrowed time.
Radiator will need to be fixed, has a small hole right next to the upper hose mount.
Has a small hole in the driver's fender in the dog leg.
Some rust in driver's foot well by the rocker.
Rear foot well needs replacing.
Installed a new dash pad, better bezels, and a 150mph speedo. Speedo doesn't work, never chased it down as I put very few miles on the car. Also installed bucket seats in it. The passenger side seat doesn't move back and forth like it should, but I have a spare set of tracks still on another seat.
Driver's front window is a little wonky, it needs help when rolling it up.
New tie rod ends, idler arm, and sway bar bushings.
Wiring has been improved, but there is still a wire or two to go over and find where it's bare, the tail lights weren't working, but did after moving the wires by the rear door rocker panel. I didn't do any further investigating as they were working the way the should when I left on my last voyage.
AM/FM radio installed. I never actually turned it on, I don't usually listen to the radio in my old cars.
I have the original bezels and some extra parts, including a passenger side kick panel vent.
You can read all about my time with it here:
UNBREADED! '71 Monaco Wagon
Asking $7,000 with the Torque Thrusts,
or $5,500 with the original wheels and covers
Original wheels and covers go with it either way.
Like the torque thrusts. 15x7? Someone told me they have 3.75 back space? True?
What size tires? Any issues with rubbing? Thanks, Ben
15x7 up front with 245/60's, 3.75" backspacing, and 15x8 with 295/50 in the rear, 4.5" backspacing. No issues whatsoever.
