T-revorNobody
At the time of posting, this CL listing is 11 days old.
1972 Dodge Monaco Three-Row Station Wagon - $28,500 - Sidney, British Columbia, Canada
CL Description
This is a 3-owner 72' Dodge Monaco Sport Wagon.
It comes with the Original Warranty card, Factory owner's Manual and Operating Manual. As well as the Original Sales Brochure and Optional Equipment Brochure.
I have the Original Build Sheet from under the seat, and a file folder with bills and receipts. It has two build tags on the rad support ( see them in photos).
It has only 106,000 miles on the odometer and was refinished about 20 years ago in ( GF3 ) Light Green Metallic. The interior was just redone with Factory Green Elk and Green Coachman Vinyl from SMS auto fabric and upholstery.
-The driveline is original and unmolested 360 with a, 727 Torque Flight Transmission, HD rear axle.
-This car was factory-equipped with power steering, power disc brakes, power rear window, hidden headlights, roof rack, roof spoiler, and rear-facing seat in the third row. The factory AM radio still works and has the optional rear speakers. The Magnum 500 wheels with spinners are 17" and make the car stand out anywhere you go. I just installed 2-1/2" TTI exhaust and Flowmaster mufflers, along with electronic ignition, MSD plug wires, and coil. The engine just had a full oil change and filter, the transmission was just serviced as well including the filter and gasket. All dash gauges function as they should, I replaced the dash voltage regulator, fuel sending unit, and temp sending unit.
The car runs and drives excellent and is great on long cruises. The paint shines and shows well, I detailed the underside of the hood and a few other areas. I left the motor as is because it doesn't burn any oil the valve cover gasket stopped what leak I could find.
You will look long and hard to find another. The car is located in Sidney B.C. and insured to drive anywhere. We are about 10 minutes from the ferry. Bring a trailer, or bring your plates and drive home a Collector.
More pictures available, on request.Collector plate eligible.
CL Description
