1974 New Yorker Driver's side mirror
Joe Raymond
Can anyone tell me what other mirror will fit a 74 New Yorker? Honestly, I'd like to ditch the cable control and just open the window to adjust it since both cable op mirrors I have also have broken cables mounts.
I daily my Norker when gas is cheap so I don't care about correct, just that it functions.
Thanks.
Joe
There was an NOS d.s. mirror for sale on here a while back in the box. However, big money. I thought about it for my car.
If you drill holes, I suppose you could make anything fit. But if you are after a drop in replacement, then it's 74-78 Chrysler...that's it.
I'm sure you can acquire a cheap replacement from someone here.
I'd assume that you'd be able to just remove the cables, even if you have to cut them, then you'd essentially have the manual mirrors. I believe Chrysler did make a manual mirror, if you'd like to go the "proper" way, you could probably find a parts car with that
I have these NOS:
3548753 one is rectangular, and the other is round 1974
3548753 is the casting # on the base, not the number in the part book 1974
also have this NOS
3760926 Left rectangular manual door mirror (3695891 is cast on the part) 1974-76 Chrysler
Nope...if you cut the wires, there's nothing to hold spring tension and the mirror will flop around.
