3" Backing Plates
66/440
TEXAS
I'm curious if the 2 1/2 brake backing plates will work with 3" shoes. I don't
think they will but wanted to check with the experts.
No —- you must find 3 “ Backing Plates —- most commonly utilized on Police Cars and Ambulances…..
I do have *** N.O.S. *** Asbestos *** 11 “ x 2 1/2 “ and 11 “ x 3 “ *** Brake Shoes —-
The Softest , Smooooooothest Braking System known to mankind —- and doesn’t rip up Brake Drums to smithereens….
Thanks, gotta find the backing plates first.
^^^ Definitely going to be tough to find ^^^
Need to find out where some unmolested Police Cars and Ambulances are hanging out in a junkyard around America…
Good Luck on the search…..
Yours, Craig…..
Hey Charlie ,
I don’t have the MOPAR Books to tell about backing plates —- the Brake Shoes are definitely the same 11 “ x 3 “ …..
Can someone please chime in to this thread who would have the correct answer ????
( I didn’t think about that possibility —- that could be
66 / 440 s much faster solution !!! )
Craig, will the ones from an Imperial work? '65 or '66?
Hey Charlie ,
The rear brake support, or backing plate, for 11"x3" rear drum brakes were the same on the C-bodies and the D-body (Imperial) for each model year from 1963 - 1971. 11"x3" rear brakes were dropped for C-bodies in 1972, but continued on the Imperial into 1973.
The part number changed due to revisions but the shared applications remained the same. The part numbers for the 11"x3" rear brake support and the years used are as follows:
  • 1963 - 1964: part numbers 2266892 & 2266893
  • 1965 - 1967: part numbers 2405752 & 2405753
  • 1968 - 1970: part numbers 2880648 & 2880649
  • 1971 - 1973: part numbers 3461986 & 3461987 (Imperial only in 1972 and 1973)
