65Polara500
I know there is a ton of information out there on this but I was hoping to get some help specific to my car. It is a 1965 Dodge Polara with the single pot of death 4 wheel manual drum. I bought the Leed brake kit FC2003-8405 which converts to power front disc. I have already installed rotors, calipers, etc. The wheel stuff is done. My problem is with the brake booster. The rods that connected the booster to the pedal were too long. I did call Leed and they sent me a smaller rod but it is still to long. When you press the pedal to the floor there is a bolt with a cotter pin that catches the side of the booster mounting bracket and sometimes gets stuck (first photo). I have not finished the install so I don't know if the pedal will actually travel all the way to the floor when completed but I don't want to do all the work of bleeding etc. and find out it does with the hazard of the brakes hanging up and not releasing. I would like to get the factory booster and master cylinder but do not know what to get. There are so many options with single diaphragm, dual diaphragm, etc. I have also read that I would need a power brake pedal assembly because it is different than the manual brake pedal assembly. Not sure if that is true. I do know that I should not use the power drum brake booster. Also a lot of the boosters have 4 bolts that mount it to the fire wall but my car has two bolts on the top coming out (second photo). Any help is greatly appreciated. Thanks
