Razbo
My '61 Dart is a Phoenix 2dr HT. I'm having difficulty finding a trunk mat. Is the Polara 2dr HT trunk floor/trunk mat longer than for my Phoenix? From the outside the Polara rear fender appears longer to me than the Dart's.
The Polara wheelbase is 122 inches and is 212.5 inches long.What is the difference in the wheelbase and total length of the different models?
If you can buy a Polara mat but not a Phoenix, and the Polara is longer, just "trim to fit" as to length.
The 1961 Phoenix [Dart] and Polara have the SAME trunk floor. Both models also share the same trunk lid.
The difference in the wheelbase is the floor panel located behind the rear seat. That is why the rear door is longer on a Polara 4-door and does NOT interchange between the 2 models.
For a 2-door the front section of the rear bodypanel to door jamb area where the rear door would be located is longer.
All of the above information can be found & confirmed in the master parts catalog. It lists only 1 part number for the trunkfloor.
Thanks for your reply and explanation. Going to order the mat that I located. FrankThe 1961 Phoenix [Dart] and Polara have the SAME trunk floor. Both models also share the same trunk lid.
Thanks for your reply. Didn't have to go dig into my manuals thanks to the information SpaceWagon gave. FrankIn many of the Chrysler Corp factory service manuals, in the back "Body" section, is a graphic with the dimensions/diagonal measurements to use when doing collision repairs on the body/frame of the car. Those could pinpoint where the length differences really are between the two cars?
One other dimension that could be considered is the Rear Seat Leg Room on the 4-dr sedans. Is it proportional to the wheelbase increase or not?
No disagreement. SpaceWagon further explained why the Polara and Dart trunks are the same length. I looked at my service manual afterwards and then realized the trunk diagrams were for both Dodges.
