rathmor
OK I had a coil go bad and it took out my Ballast resistor. Changed both and had the spark and engine going for a few. Now the ballast resistor is shot again. I've tracked the wires and didn't find any breaks or grounds anywhere. I am wondering if there is an easy way to see if the Distributor is fried and causing the back feed or any other ideas on why the ballast resistor keeps burning up.
As always thank you everyone for your help and guidance on this
I miss having my father around to help and get me thru the stuff I am still trying to learn on older motors.
