WANTED '65-'68 Spring Shackles
D Cluley
Lansing MI
I'm looking for 1 or 2 of the leaf spring shackles used on the Slabside C bodies. These are the straight ones, not the offset type used on station wagons & the later cars.
Part number is 2585 262
They are about 4" between the bolt centers & about 3" wide.
I'm interested in either good used, or a source for new ones if they exist.
Thanks to all.
I currently have the universal sort on the car, and it seems like there is more side to side play than I like. They may just need new bushings, but it seems that the factory design where the bolts are pressed into one side plate should be stiffer?
Sounds like Rainy Day has what I need, so that's the plan.
I am going to do some more research and may make another post if I can get some of this sorted out.
That ACDELCO part seems to be discontinued and sold out everywhere but poking around with that number & what it fits, turned up this option.
Chrysler / Dodge / Plymouth Leaf Spring Shackle
Their list of cars it fits seems odd, so I'm not 100% sure it is right, but it may be, and it is possible that some of the A, B & E body parts could work as well. It is hard to get all the dimensions from any one source.
