'65 Polara Rear end size?
ArmedGinger
BC Canada
What rear ends came with the '65 Polara V8 models?
7 1/4
8 1/4
8 3/4
All of the above?
My father is looking at a '65 Polara and they seller has no idea which the rear end is, only that it is limited slip. I sent him a picture of what the rear ends look like but the car is currently in storage and my father is about 12 hours away from being able to go look at the car. Just trying to get a better idea of what might be in the car. Currently has a rebuilt 360 under the hood, bench seat. Good shape.
You can probably download a Dodge or Plymouth factory service manual at www.mymopar.com to look for the correct size. Usually determined by engine size and body series combinations. If the car has a 383 or larger engine size, it's probably a 8.75 rear axle. Check the service manual for details.
Might need to manually input the web address if the link does nor work.
