Hi all. Need a 727 expert over here. Have a 65 300L that's been sitting for a decade. Reverse works fine. From a dead stop I can put it in D and I get whirring and slipping. Same in 2. Pull it into first the noise goes away and the trans engages. Once rolling I can shift into drive and everything is fine. Come to a near stop and the whirring comes back and the trans slips until I put back into first and get rolling again. I'm assuming its a pressure issue, the rear pump helps overcome when rolling, but I know next to nothing when it comes to automatic trannys right now. So my question is, does it sound like I need a overhaul, or is there a band adjustment or maybe filter swap needed? If it sounds like the trans is dusted should I just put aside and get a later 727 trans/converter with part throttle kick down and the Imperial Services adapter kit until I can get a 518 ready to go in???
