ian taylor
hi again folks, buying all the stuff needed for the rewire.....need new connectors for things like the headlight switch, ignition switch and especially the instrument connectors.....any ideas?
woukld prefer new as rewiring, not many used sets here in the uk 8)Do you have to have new, or will used work? You could clean up a used set.
awesome, need the two instrument plugs and the headlight plug. if you're parting out cars i also have what looks like a radio shaped hole in the lower dash, will post a couple of pictures. cheers ianI understand. I have 3 dashes to choose pieces from.
I have some spares on the shelf I can check in the morning.awesome, need the two instrument plugs and the headlight plug. if you're parting out cars i also have what looks like a radio shaped hole in the lower dash, will post a couple of pictures. cheers ian
hi, also after rear glass for a 2 dr h/t and a drivers ashtrayI understand. I have 3 dashes to choose pieces from.
