Unless there's some trick about making enough room to get the old mount out and put the new one in, I'm stumped for now. I've removed the 2 bolts holding the mount to the trans, and the single nut holding the mount to the frame cross member, have jacked up the trans until it's making contact with the underside of the floor, the old mount (which is quite beat up but hasn't separated) is loose and I can move it around but can't find any angle to extract it. It's somewhat spongy and has some give, but the new one is rock solid and would be even harder to put in:
The mount must drop into a channel in the cross member and why they made that channel so deep, I don't know. It's a real pain. Even if I had an extra 1/4 inch that would be enough to slide the new mount in but that stupid bolt sticking up would be the next problem.
The way I see it, the only way to do this is to also disconnect one or both engine mounts and lift the engine and trans simultaneously, and that *might* work.
Alternatively, I cut the bolt off and drill and tap a hole on the other side (the other plate) and fasten that side to the crossmember with a bolt.
Has anyone else had to deal with this?
Regarding the U-joints, I thought I could unbolt the half-circle hold-down plates and remove the 2 joints, but that's only partially possible on the rear joint. How exactly do you remove the joints? They look pressed in.
