67 Newport custom 4 door window channels
bodydropped72
bakersfield,ca
Looking to find some replacement window channels for my 67 Newport… all 4 door window vertical window channels!!! I’ve done a search through many of the “parts supply” online stores but all they show is a and b bodies. From what I can see is it’s 3 individual pieces per window. The 2 “vertical” guides for inside front and back of each door and the horizontal one that is just that, goes into the top of the window frame. Thanks in advance
Is this a sedan with a solid frame on the door around the door window openings?
Something about your description does not really fit either the 4-dr sedan or 4-dr hardtop, as to "channel". Might download the Chrysler Parts Manual at www.mymopar.com and look at the illustrations of window channels/hardware for verification. You can also find a Chrysler Factory Service Manual for download, too. Whether Plymouth, Dodge, or Chrysler, brand does not matter as they were all the same components within a particular platform (i.e.,, 65-68 Slabs, '69-'73 Fuselage, '74-'78 Formals).
