strokerpost
If you have a restored 68 440 car with A/C, or a car that is in very good ORIGINAL condition or at least reasonably so I would like to see some underhood pix. I'm wanting to know the correct way things were painted, especially the black stuff, rad, A/C comp and lines, pulleys, P/S pump, etc. if you want to add in your own knowledge while you're at it that would be most welcome too!! I just found out today that my 300 with the original 440 has the wrong carb on it. It has the Holley list# 4440 which is for a 68 or 69 383. Mine should be list# 3918 or 3918A. The 4440 is rated at 570 cfm, that could explain the not so impressive giddeyup! LOL. Anything you guys can add will be appreciated. Thanks.
