I just finished my 68 Chrysler Newport Custom with 383. Kind of curious what I could get for it just asking for now.
Recent things done (Engine and Suspension)
-Motor rebuilt by Previous owner, Flat Top Pistons (2008), had heads off no carbon or black at all on the pistons, walls were in excellent shape
-Heads re done, 906 heads cracked, currently 346 heads with hardened seats, New Head Gaskets
-Comp Cams k-21-223-4 just put in May 2014. Duration 268/280, Lift .477/.480, Double roller Timing Chain, Heavy Springs with damper, 10 degree locks.
-Edelbrock 1805 AVS Thunder Series 650 CFM
-Performer Rpm Intake
-Hedman Shortie Headers
-New water pump,thermostat, thermostat housing
-New Aluminum Radiator, car doesn't get above 160 even in 90 degree temps
-New Belts, Hoses, Spark plugs, spark plug wires, distributor cap
-Pertronix electronic ignition kit and Pertronix Flamthrower 2 Coil
-New fuel pump, fuel filter
-Only thing not replaced was oil pump.
-New motor Mounts
-New tranny filter and pan gasket
-New Shocks, rear has load levelers
-New upper and lower ball joints
-New Wheel cylinders and brakes
-Brake lines new accept rear one in good shape.
-Fuel lines in good shape
-New Gas tank and straps
Recent Things DoneBody and Interior)
-All trim removed fixed rust on lower fenders and quarters(Rust eliminated but body work not perfect)
-Roof was pitted filled in with body filler(Not perfect but much better)
-Any rust spots were treated with rust mort
-Entire inside of the car inside the doors, and trunk were treated with rust mort then painted with por 15
-Frame was coated on the inside with eastwood frame coating
-New Carpet
-Heater core box rebuilt with new motor and heater core
-Seats are original but have seat covers as they aren't in the best of shape more the rear seats.
-Aftermarket Fuel, Oil Pressure, Temperature, and Rpm
-Rear window had some rust on the upper driverside corner, removes all old weather stripping treated rust with rust mort, painted inside the grooves with por 15 resealed and put chrome back on
-Trunk repaired with trunk extensions.
-Firewall did have some minor holes in it cut and patched with gorilla hair.
As far as the paint I primed it with primer sealer. It might not look pretty but this car runs great has better power now nothing mechanically wrong at all, there wasn't before I upgraded to 4 barrel. Paint and Body work which is the most expensive thing has to be done or if someone likes the way it looks leave it because I like the way it looks as I am not a gloss and shiny paint person. Like I said just asking opinions on what I could get for it. I know c bodies aren't in high demand. I have seen some for $3500 with rust and the motor would need to be rebuilt so I really don't know where I fall.
-New motor Mounts
-New Carpet
