The time has come to replace my Carter 2bbl 4608S as it won't hold a tune after a rebuild and is failing a vacuum test according to my trusted mechanic. Is the general idea that you can swap any 2bbl with another 2bbl? (Identical bases, etc.?) If anyone can weigh in here I don't have the knowledge yet to tinker with it myself. It's either try to go with a known brand or buy 3-4 Amazon generics and hope I get lucky. ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
This is the one I'm looking at as it seems pretty simple. And an aluminum spacer since the paint around the base of the old carb is a bit melty and discolored from heat.
