69 Chrysler 300 rear end
20get
Twillingate Newfoundland
I'm wondering what options were available for the 69 300 rear axle. Is the sure grip a standard feature with 3.23 ratio?
Thanks!, I'm in the process of buying a 69 Chrysler 300 convertible, all original with the non TNT motor. Console shifter and buckets. Just wondering what type of 8 3/4 rear axle to expect.
Thanks! From the info I gathered so far, I understand that the 3.23 was standard, with the 2.76 as an option. From what I read the Sure grip differential was also standard. I'm trying to clarify if I'm correct or not.
Most likely 2.76 ratio with an open rear.
You have it all backwards. 2.76 standard for the 350hp 440. Sure grip optional. See my post ^^^
