cuda_conv
My original heater valve does not block water.
Reading the FSM this valve is normally shut with no vacuum and opens fully with full vacuum.
If I blow into the vacuum pod I can get the water to a slow trickle.
I like the concept of the 4 port valve mentioned by 66/440 and picked one up but this valve works completely the opposite.
It is fully open with no vacuum and fully closed with full vacuum.
Did I pick up the wrong valve or is there a different valve that will work?
