Carl Severa
Good morning!
I've had a situation with my Monaco where I've had to jump start it either by using jumper cables and a vehicle that I can jump from or using small jump start battery boxes. Typically, the car starts with no problem. I've been starting the car like this for a long time.
I've had to start the car by these methods because the driver door is bent from an accident and the dome light button does not get pushed in to turn off power going to the dome light. Even though I have the bulb out it still seems to drain the battery. There may be other factors in play, but I don't know what they are if there are any.
I took the battery to a local service station yesterday and they charged it and it was determined that the battery was defective.
So, I took a good battery out of my Jeep and put in the Dodge and the car still fails to start. The Jeep battery is compatible with what the battery is for the dodge.
The only reaction from the car that I get when trying to start it is, sometimes, a single click and then nothing further. If I turn the key off and then back on to try starting the car a second time I typically get nothing.
I'm wondering if somehow in the recent attempts to start the car I damaged a component in the electrical system, which would include the Pertronix ignition component I installed a good while back? I guess that would be similar to my damaging what would have been points and condenser.
At this point, I'm going to have to have the car towed to the shop because I can't conduct any for the diagnostics. But, I'm curious to see if I may be needing to order and replace the current Pertronix s component and if there's a way that I can determine that.
Thanks for any suggestions.
Carl
Carl
