70 new yorker wheel studs
moparmick
uk
Hi , can anyone tell me if a 70 new yorker has LH wheel studs ? , and what size are they
Thanks in advance
From the factory ( a.k.a Original )
The Four Wheel Drum cars would have had LEFT Front & LEFT Rear Wheel Studs om the LEFT Side .... and Right Front & Right Rear Wheel Studs on the
Right Side.... Fronts and Rears are different....
The Front Wheel Disc / Rear Drum cars would have had LEFT Front & LEFT Rear Wheel Studs on the LEFT Side .... and Right Front & Right Rear Wheel Studs on the
Right Side .... Fronts and Rears are different .....
Front Disc and Front Drum Wheel Studs are different.......
Everything mentioned are all 1/2 " ..... All " B " Body, " C " Body , and " E " Body all use 1 / 2 " Wheel Studs.......
Usually, the LEFT studs had an "L" stamped in their end. Visible so the lug nut installer could see it if they looked.
Yes, 1970 left side of car has left hand both front and rear.
1/2" X 20
