SOLD 71 300 chrome trim
C Body Bob
Youngsville, NC
Feedback: 24 / 0 / 0
from a 2 door vinyl top car. This is the rear lower corner trim at the vinyl. The mounting pin for the driver side has the tip broke off. Should not be a problem. Still plenty to run a twist nut on. Some scratches & lite pitting. $25.00 ea side plus shipping from Raleigh, NC. I can also polish these for an extra $35.00 ea piece so they will be clean & shiney when you get them
Hi, do you have experience on how to remove this trim ?
I would be grateful to be taught, as i will have to replace a vinyl top in coming weeks...
Yes it's comes off easy. You remove the screw at the end & then way up under in the trunk there is a twist nut. I think it took a 7/16 socket. Be carefull to not break off the stud the nut go's on. Then carefull pry it up & pull it off
