Nick C
I went to start my NYB today and when I turned the key to the crank position I heard a 'pop and crack' sound and it seemed like everything went dead. Now when I go to crank it none of the lights light up on the dash and the starter will not crank. I replaced the starter relay but it did not fix it. Then I tried jumping the relay with a screwdriver but still nothing. Additionally the parking and headlights will not turn on and none of the accessories work when I turn the key to start or accessory. However, the power seats, the dome light, and the buzzer for when the key is in the ignition all work. My battery is at 12.79 volts, the fusible link wires look good when I inspected them, and I have power at the starter relay. Where do I go from here to find the problem? Any help is appreciated.
