Ironram
Looking to add a 6 space fuse panel. I need a good switched power to supply power accessory panel, any ideas? TIA
You can use switched ign power to control the relay. What are you planning to power?add a relay and take it right off the battery
If you are just running power for gauges, you can flip the fuse block over and use a spade connector to the accessory buss bar. I don't know what year car you have, but many of the cars newer than 69 have a connector on the face of the fuse block that you can use.
