all set
go to wilwoods site to check, but I put their cbody 6/4 setup all the way around on mine and barely clear 15" aftermarket aluminum wheels over the calipers with their 12.19" rotors, you will need to know what size rotors are on it but probably won't be able to fit 14's especially if they're steel 2pc wheels
The smallest Wilwood kit has an 11” front rotor and clears 14” wheels. If the seller knows the part number of the kit they used, or measures the rotor, you can cross reference it on Wilwood’s site to figure out if it is the kit for 14” wheels or not.
just keep in mine it does not necessarily clear all 14" wheels, my kit said it clears 15" wheels however only about half I was interested worked and none of the steel 2 piece would. It all depends on the barrel shape, drop center location and depth, and angle of the face from the hub mounting location. Bottom line you really won't know until you test fit when trying to go with the minimum size they say may fit. The wheel manufacturer said the ones I went with would not fit after sending Wilwoods schematics for front and rear dimensions for my specific kit and wilwood said to test fit first but after test fitting each size front/rear I ended up with about 1/8" barrel clearance and working perfect for the offset/stance I wanted.
