angled plug heads gonna be a problem?
Cartel
Chilliwack BC
I am still trying to factor in getting aftermarket heads for my 383.
If I get angled plugs, is that gonna be an issue with hp manifolds or logs? I'd like to get the engine running and worry about headers or hp manifold later. Are angled plugs gonna be a problem?
thanks
Logs might be ok, but angled plugs with HP manifolds put the boots in danger of getting burnt. Lots of reports of that on Moparts with angled plug heads.
As things have evolved, angle plugs are not as necessary for good combustion as they were once thought to be. I suspect that a modern chamber might not need them as much as a prior chamber would have? Not to forget the impact of the fine-wire Iridium plugs have on combustion dynamics.
