A lot of new Mopars, good turnout overall, my car won't be ready for at least two years.Sad I missed this but my car hasn't had steering in months and yesterday was the only opportunity I've had to work on her in a long time.
I hope everyone had a good time!
Almost. Everything is installed but nothing is torqued. I did that purposefully as I was concerned my pitman arm would be off a tooth or two. I was correct. So now I have to drop the center link off the pitman and Idler arms, correct the pitman arm's position and bolt it back up.Well. . . Didja finally fix it?
Even then, my alignment is going to be half a**ed at best... just good enough to get it to a shop which I probably wont be able to afford until the spring.
Oh yea, I've fudged it on a few vehicles .. I don't think it's too far out now, actually (once i fix the pitman's position) and I'll likely be able to limp it around for the fall. I just want to sock dough away this winter and get a lot of mechanicals done in the early spring.Great! I think there is something you can do on a budget workaround with string to align the front end, and you can get it pretty close. The FSM may spell out the procedure or it may be found somewhere else. I just don't remember where I saw it.
