For Sale Auto Temp 1 Parts for sale
MONC440
Michigan
So I pulled all of the auto temp under dash parts out of my car and replacing with manual A/C. I have no idea if the system as a whole works or not because my car didn't have a compressor so I never tested it. I didn't want to take a chance on it so I converted to manual A/C.
Dash control; buttons move freely, the vacuum switch works and sends vacuum to the proper ports. The A/C switch works when you put it in an A/C mode and the fane switch works for A/C and Heat/Defrost selection. The thumbwheel changes resistance when rotated so I assume the dash control in good.
Control Unit Assembly: Untested
Water Valve Thermostat; Vacuum Tested and it moves
Recerc Transfer switch: Broken
Check Valves: Work
Blower Motor Resistor: Untested but looks intact.
Master Switch and Compressor switch: Work
All vacuum lines intact.
Wiring harness: All there except for the wires that go out to the blower motor and A/C compressor.
$150 for everything or make me an offer on individual parts.
