chris53190
will the broadcast sheet tell you what rearend/gear ratio a car has. any help would be great. thankyou!
Yes it will . Have you looked ON the rear for the tag? If still there that will have the ratio on it
First you yell at me on the Y code thing and now my panties are in a bunch???
Thankfully my panties are baggy on her.
68 and older it will be on the fender/data plate, 69 and later not.
Broadcast sheet on all.
Alan
Gear ratio can be found on 69 - ?? Lynch Road tag via axle assembly code.
Where can one find the rear end ratio on a '66 and earlier tags?
