Hopefully some one can help me out. Can't seem to get carb right. Not once have I been able to check my plugs and have them be the correct color. They are always on the dark to black side. Last Saturday when I started the engine, it was running rough, misfiring and seemed to be running on only six cylinders. So I pulled the #8 plug and sure enough it was gas fouled. I decided to replace all the plugs and found two others that were also fouled wet with gas. Replaced all the plugs and now it runs good. A friend in work say's he thinks the carb is leaking fuel when the car is sitting. How do I check this? And how do I fix it? The carb is a Edelbrock 1405 600cfm that is fairly new. Otherwise seems to run OK. Starts good. Good response.
Just black plugs. Thanks for any help.
