I'm getting happier about how this carb is working on my 318, cold start performance is pretty much tuned up but I still need to work on getting better early choke pull-off. This is a china clone of I think the Super-6 carb, which I think came out in '77. I might get more / better answers from FABO on the following questions, and I get that, but for what it's worth:
Even when I look at all sorts of diagrams, parts diagrams for the Carter BBD's, those diagrams never show the carb from the back-side, and hence they never ID these back-side ports. I have most of them plugged, like 7, 3 and 8.
1 goes to the PCV. 5 goes to the distributor advance. 6 comes off the top of the air horn "tin hat" and it's open but there's really no vacuum from it, I think it's for the charcoal evap canister.
Now my current question concerns port 4, which comes off the throttle body and for which there is no equivalent on the 2 or 3 actual late-60's early-70's Carter BBD's that I have. I've been using port 4 to measure manifold vacuum to help tune the mixture screw and set timing. I can easily get 18 inches, sometimes 20 inches at idle. But otherwise I plug port 4. But today while the engine was idling I removed the plug and the RPM's went up a little. And that's what I'm wondering about. Is this port 4 supposed to be open? The underside of my air cleaner housing does have a nipple for a small hose, I seem to recall that a small line once was connected to it from the carb. There's also port 8, which I'm wondering about what it's for.
Another question. For those that might know about the Carter "Super 6", were those ever put on 318's back in the day? Did Carter ever come up with a "Super 8" BBD for the 318?
If in the late 70's / early 80's the slant-six's were getting the Super 6 carb, what were 318's getting?
