For Sale Carter WCFB
haywire 440
Get The Cartwright
Arkansas
Feedback: 9 / 0 / 0
No #’s were found, the choke vacuum pull off is broken. Asking $65 plus shipping.
The casting numbers may give some clue as to what this was from, although you can't really ID a WCFB from casting numbers alone.
The air horn casting number is on top, in the left rear quadrant. Usually formatted like "6-XXXX"
The main body casting number is on the front of the bowl, left side. Usually in the form of "0-XXX" You can even see it in one of the photos above.
The throttle body number is usually only readable if you remove it from the bowl. It's on the top of the casting, on the throttle lever (left) side, between the throttle lever and the bowl gasket (in the crevice). Usually "1-XXXX" format.
Here are the casting #s
6–1020 **
0-1030
1-1332 A
This what I think they are, though the 1 after the 6** is cut off.
