Take the pan off and look at the front counterbalance.....machined or rounded from pounded.....nah. The cast crank has much more carbon than the forged. Forged has lots of alloys that the cast does not...Soooo, just take some fine paper, 1000 or so and polish the nose of the crank. Then apply just a taste of hydrochloric to etch it. The grain structure is the key.....the pounded forged has an aligned grain, and the cast has a random grain. After application of acid, use a good power loop and examine the end of the crank nose to look at grain structure. The results are obvious....and you dont have to take the pan off to figure out internal or external balance.....voila!
