I feel some "stiffness" in my .. er .. neck. yeah, neck. I dig this car.
For posterity.
SELLER DESCRIPTION: $17,000 or best offer.
This is not your grandpa's Chrysler. This car is one of the baddest REAL street cars on the road. Every modification was done with streetability in mind. This car is a wolf in sheeps clothing. This car was built to street race and will hook on the street when the tire pressure is lowered to 11-12 psi and the road is mildly prepped. There is not many cars that will beat this car on the street. That is a fact. Keep in mind that this car has an old school 3 speed automatic and 3.91 gears so it screams going down the highway at 70 mph. I'd suggest taking alternative routes that have 55 mph speed limits so you can hold a conversation with your passengers. If you haven't driven a car of this caliber, you should probably not waste anymore time reading this. This car makes a lot of power and can very easily get an inexperienced person into trouble or seriously injured. I've been drag racing my whole life. I've gone 9.30s at 145mph with a 10.5 tire car and daily drove the car in the summer. I'm not some chump that advertises a stock Mustang as "super dooper fast". I am the real deal so trust me when I say if you are inexperienced, this car is not for you. I refuse to exchange money for someone's safety or put someone in harms way.
Here is a video of a start up of the car
and one of the car idling and a walk around look at the car
The car is heavy as a pregnant elephant. I weighed it the other day on my Intercomp scales and it sits pretty at 4,172 pounds. But the car is all steel and real steel from the 60s. There is plenty of areas to shave weight from if you so choose. The car has power windows and power seats. It is an original air conditioning car and I have all of the factory A/C parts that will go with it. This car is rare as well. It is a 2 door hardtop with bucket seats and a factory console and floor shifter. I have only seen 2 others besides this one. From the information I found on the internet, there was less than 2500 made in 1965. This car is a rust free beauty that has extensive modifications. The car can be driven anywhere, any time. The wipers work, the horn works, etc. The paint is from the late 80s and has flaws because the paint is old and the car gets driven. The heater hoses are not hooked up because I don't know if the heater core leaks nor do I care. The heat coming out of the cowl hood keeps the windshield free of fog, frost, dew, etc. The carpet is excellent but the front seats could use some stitching, they're old. The car runs 180-190 degrees no matter how hot it is outside. The transmission runs 150-160 degrees. The car runs great down the highway, shifts good and firm. The ball joints, tie rod ends, brakes, brake hoses, master cylinder and several other items have been recently replaced. J&K Summerfield's did much of the work.
Below is a list of some of the modifications done to this car.
Engine: 500 cubic inch Chrysler big block
- 1968 440 HP block. Deburred, magnufluxed, sonic checked, etc.
- Eagle 4.150 stroke crank
- Eagle H-beam Rods
- Venolia Pistons 4.380 bore - 11.27:1 compression ratio and runs on 92 octane pump gas
- Fluidampr balancer
- B&M SFI flexplate
- Milodon Oil Pan
- ARP bolts everywhere
- Howard's Solid Roller cam
- Crane Cams solid roller lifters
- Smith Brothers Pushrods
- Trick Flow Max Wedge Heads
- Manley Nextek Valve springs
- Manley Titanium retainers
- Crane gold race shaft rockers
- Edelbrock Super Victor Max Wedge Port Dominator intake
- Holley 1050 Dominator
- Fabricated Aluminum valve covers
- TTI 2" primary ceramic coated headers
- MSD pro billet distributor
- Milodon billet oil pump driveshaft with bronze gear
- Aluminum water pump housing
- Electric Water Pump
- Polished aluminum timing chain cover - 2 piece with removable cover for easy cam access
- GZ Motorsports Vacuum Pump
Transmission: 727 Torqueflite
- updated planetaries & servos
- 4.2 High Ratio Band apply lever
- Turbo Action Manual Valve Body
- A&A Deep Aluminum trans pan
- Hughes Pro VI series 4200 stall torque converter
- SFI Transmission Shield
Chassis:
- Chassis Engineering Pro Ladder Link Bars
- QA1 rear coil over shocks & springs
- Chassis Engineering Panhard bar
- Mopar 8 ¾ rear end with 742 case, Sure-Grip and Richmond 3.91 gears
- Weld Pro Star wheels 15x4 front and 15x10 rear with 325/50 M&H Racemaster drag radials
Other stuff:
- MSD 6AL ignition
- MSD HVC-II coil
- Champion Aluminum radiator
- Flex-a-lite electric fan
- JAZ fuel cell with Chrysler sending unit
- Aeromotive electric fuel pump
- Aeromotive fuel pressure regulator
- Aeroquip braided hose -12 from cell to pump and -8 from pump to regulator
- Aeroquip -6 braided hose from regulator to fuel bowls
- Aeroquip -6 braided hose from Transmission to trans cooler
- Permacool transmission cooler
- X-pipe, Flowmaster Mufflers and turn downs
- Autometer Sport Comp II 5" tach with shift light
- Autometer electric water temp gauge
- Autometer electric trans temp gauge
- Autometer oil pressure gauge
- Autometer fuel pressure gauge
- Autometer vacuum gauge
- B&M Quick Silver Shifter modified to fit the factory console
- Hurst roll control line lock
- Lokar Throttle cable
- Lokar transmission dipstick
- Billet throttle bracket
- Billet fuel regulator bracket
- Flaming River steering shaft and joints
- New upper and lower ball joints
- New inner and outer tie rod ends and sleeves
- New manual steering gear box
- New Master Cylinder
- New brake hoses
- New wheel bearings
- New brakes
Feel free to ask any questions if you are serious about the car. Don't come to test drive it if you don't have cash in hand. I will take you for a ride if you serious about the car but you will not sit in the driver seat if you don't have cash with you. I am open to offers but don't waste my time with ridiculous low ball offers. Realistically, what I'm asking is a small portion of what is invested in this car. Anyone that knows what they are looking at knows what this is worth and knows this is a hell of a deal. Don't ask me "what my bottom dollar is" or "how much I'll take" before you look at the car. Don't make me an offer before looking at the car either. How the hell can you make an offer on something if you haven't looked at it? No tire kickers or joy rides. If you don't have money or have no intentions of buying this car, don't waste my time. If you are serious about the car and have cash, we can negotiate. I do have some flexibility in the price. I don't need to sell the car, I want to sell the car but I'm perfectly content with keeping the car if need be. Clean and clear title.
