1Fury1
Slab Side Slacker
I have the pedal assy out so as to McGuyver some linkage with the correct amount of travel for the hydraulic clutch master mounted on the firewall.
The existing OC spring which is anchored between the pedal lever about halfway down and a pin at the top of the pedal assembly, apparently helps overcome some of the pedal pressure.
Can anyone with experience in the mechanical to hydraulic retrofit tell me if this spring is still needed with a Hydraulic TO bearing setup? I can work around it but asking because it's kind of in the way right now.
