Dan Scully
Working on the 70 300 convertibles. Have not looked at a wiring diagram yet, the door jamb switches where bad, replaced those. The lights in the rear bottom inner door panel now come on with the doors open. The console side lights, and rear light do not come on with the door open. Tried using the headlight switch that I assume completes a ground to turn a dome light on if it had one. The connector at the console plug has a pink wire which is a power feed, by grounding the yellow wire at the 4-plug connector the all the console lights come on. Should the console lights come on with the door jamb switches or only thru the headlight switch? Thanks for any help on this.
