WANTED Cruise Control switch
Omni
Good Day All
Looking for a cruise control turn signal switch for a non-tilt column. Only need the switch, but am open to other cruise related parts.
Drop me a PM if you have one you want make go away.
Merry Christmas
Omni
Good Afternoon
Actually no. Just looking for a 70's style switch. Adding cruise on an 'A ' body that never available that I know of.
Omni
Good Evening
As long as it is a four wire switch for a non-tilt column the either style (barrel or slide resume) will work. The attaching point on the turn signal switch switch is key. It must be identical to a non cruise turn signal stalk.
The mid 70's style (slide style) is probably the most common.
Omni
