66Newyorker
After installing the new rebuilt engine I have noticed the fuel consumption has gone up and the oil pressure at hot idle was not where I wanted to see it. I ordered an adjustable oil pump regulator from 440 source. Took about 10 mins to install. Had preset the unit before install after, took a SWAG at it. Started the car and had over 100 psi. Removed the adjuster and turned the adjustment screw out until about a 1/4" past the lock nut and reinstalled. Started the car and had about 70psi cold. Now the hot at idle in drive oil pressure is about 25 or so.
Second I had bought a Wide band hand held O2 sensor from Innovate Motorsports. LM-2 Wideband O2 Digital Air/fuel Ratio Meter. Started out at about 12 to 1 mixture at cruise after some jet and metering rod changes ended at about 14 to 1 at cruise at 75. Very happy with both products.
