kenmdale
Can someone tell me which way the seal goes in for the speedometer gear seal. Does the flat side go point toward the gear , or away from it
Cheers
Cheers
So then the flat side with the numbers go outside ?General rule of thumb is that if you are sealing oil in the lip always goes towards the oil side. If it is being used as a dust seal the lip goes out.
