Not Mine.
http://www.ebay.com/itm/Chrysler-Im...e813426be&item=131016697534&pt=US_Cars_Trucks
1962 Mint Green Crown Imperial - 4 door Sedan. Originally a California car - brought to MidWest in the 1990's - has been garaged since 1997. Mileage reads 51,000 currently but could actually be 151,00? Interior seats restored beautifully! Exterior also re-done to match original color, but has some leaf impressions on the top when a tarp blew off in the Fall and leaves sat on it for a few days. 413 Engine, Power Steering, Power Brakes, Push Button transmission, Power windows (two not working properly at the moment), Air Conditioning/Heat (currently has a toggle switch inside to change from air conditioning or heating). Includes two new reproduction tail light lens (still in the box) - just recently purchased. Turn signal available but had broken off. Speedometer works but flashes back and forth? Gas tank has a leak in the upper section/can only fill tank half way. (Has never been a problem) Has a very large trunk! This is a beautiful car to drive and goes like the wind! Must be picked up locally or arrangements made for transport pick-up.
Vin number: 9223151707. Work completed in the past two months: Muffler, New Battery, Oil Change, new Filter, Spark Plug, Plug Wire Set, Condenser, Distributor caps, Contact Point, Ignition Coil and 34PS. (over $1,000 of work!)
